Pulling up the ladder and you fools ignore it every time. You voted your demise in. You will live in misery and will be deceived
by the most ancient evil.
https://www.zerohedge.com/news/2019-01- ... -instagram
http://gdxforum.com/forum/viewtopic.php ... der#p36566
Still they scoff at every word that is true.
https://www.studylight.org/commentary/genesis/4-24.html
https://www.youtube.com/watch?v=_URrAt1ZnGk
They were children of fools, yea, children of base men: they were viler than the earth. job 30:8
thread noted: lamech, amos
From the first 3 dates, there are *1335 x 2; 1290 x 2, & 1260 x 2 respectively, unto Christ. The middle two (2458, 2433 BC) are about 2300 unto 'Hanukah,' or the final bar-Kochi rebellion in the mirror (and another 2300 to Abraham's birth), & 490 x 5 unto Christ too. For 2373 BC, there are 2300 unto mirror of fall of Jerusalem (w, Masada, AD 66-73), & 490 x 5 unto the same again in actual time. From 2303 BC, there are 2300 to Christ's birth. And lastly, *2243 BC is 2300 unto the end of recorded (biblical) history of the church, and agrees w 430-year continuum back to entry into Egypt. It aligns also as the Apostle Paul going into captivity to Rome in AD 60, (Acts 28).
Use any calendar you wish since the season of the times are already set.
Once the apostle Peter asked Jesus, "How often shall I forgive my brother, unto 7 times?" Jesus said, "no, but unto 77 times" (Mat. 18:21,22; the original Greek can also read, "unto 70 x 7" or, 490, see KJV). This was more than a statement of good Christian virtue, it was also a prophecy of God's dealing with man, particularly with Israel "his firstborn" (Jer. 31:9).
These numbers, "7-times," "77-times," and "70 x 7," are found already in the OT, especially in Genesis and Daniel. In Daniel, following the same theme of forgiveness, reconciliation, etc., we are presented with an important prophecy as to when the Messiah would come (Daniel 9). We are told that this would be fulfilled in "70 x 7" years. This 490 day-year figure is further broken down into four segments in the prophecy: 49 + 434 + 3.5 + 3.5 = 490 years. The "3.5 years" is further explained at the end of Daniel where the number 1290 is given us. This '1290' is the "1260" of Revelation. 11:3, except with the intercalary month attached. (The 1260 is 3.5 years of the standard '360' year.) "Seven-times," refers to a full 7-year-period, (3.5 years x 2 of Daniel 9:27), as in Daniel 4:16,29.
This prophecy of the '490' states, "The end will come like a flood," Daniel 9:26, (uttered between the '483' and the remaining '7' of this prophecy).
The seal has been set and for 33 years I have watched three seals unfold and noted clearly. The seasons already given the sign of the times.
Aramaic word iddan appears several times: Daniel 2:8,9,21; 3:5,15; 4:16,23,25,32; 7:12,25. The word means time or a year, depending on the context. When it is used with a definite article or a fixed amount, it refers to years.
What does it mean they will announce.
"Once we squeeze all we can out of the US, it can dry up and blow away."
Sign of Jonah as warned.
“They said, ‘Well we need a physical barrier in certain places, we need technology across the board, and we need more people,’” he said.
Tactical deployments as the Guys said and we already know. Deploy, defend, defuse.
Six areas provide at least limited verification:
(1) historical setting
(2) literary context
(3) grammatical structures (syntax)
(4) contemporary word usage
(5) relevant parallel passages
(6) genre
James W. Sire, Scripture Twisting, pp. 17-18:
"The illumination comes to the minds of God's people — not just to the spiritual elite. There is no guru class in biblical Christianity, no illuminati, no people through whom all proper interpretation must come. And so, while the Holy Spirit gives special gifts of wisdom, knowledge and spiritual discernment. He does not assign these gifted Christians to be the only authoritative interpreters of His Word.
It is up to each of His people to learn, to judge and to discern by reference to the Bible which stands as the authority even to those to whom God has given special abilities. To summarize, the assumption I am making throughout the entire book is that the Bible is God' s true revelation to all humanity, that it is our ultimate authority on all matters about which it speaks, that it is not a total mystery but can be adequately understood
by ordinary people in every culture."
Corridor rat lines for trafficking drugs and even worse. The chems are imported for the cartels deployments.
Every one knows this except the main line press and the body farm clown posse.
https://mexiconewsdaily.com/news/battle ... s-21-dead/
Ford Prefect: It's a tough galaxy. If you want to survive, you've gotta know...where your towel is.
The "government" is being rebooted, without the criminals.
They are not Democrats.
The widows are housed and the children alive.
Our Governor took no credit in this endeavor. He was a blessing surrounded by self interest ideologues.
https://www.youtube.com/watch?time_cont ... vCGtxeknSg
This is what Neoliberalism looks like.
The point of the matter is they sent what they did not want there.
The socialist here will pull up the ladder dispensing what can take from you.
It is a fact not a concept. You give from scarce resources from what the marxist sent here on
purpose as they plant blue flags from illegal invasion networks called corruption.
Sorry serfs, we spent all the money on self licking ice cream cones.
https://supreme.justia.com/cases/federal/us/299/304/
As we seen in real time both sides of the isle are self licking ice cream addicts.
http://www.carrollquigley.net/pdf/Tragedy_and_Hope.pdf
"It is not that government has lacked information needed to fix the problem. It is institutionally incapable of bringing about the desired result, since the principles of profit and loss, private property and contract, enterprise and entrepreneurship, do not exist in government. Any Government operates with an eye to its own short-term survival, and those of its connected interest groups, and nothing else." Mises
Getting alot closer. Soft targets are underway. Press and now visual media soft policy. Wed Jun 06, 2012 1:31 pm
Pick one since you have no choice.
Level I - pathological defences (i.e. psychotic denial, delusional projection)
Level II - immature defences (i.e. fantasy, projection, passive aggression, acting out)
Level III - neurotic defences (i.e. intellectualization, reaction formation, dissociation, displacement, repression) <-----------
Level IV - mature defences (i.e. humour, sublimation, suppression, altruism, anticipation)
http://mises.org/books/leftism_kuehnelt_leddihn.pdf
In other words, there is a real antagonism, an incompatibility, a mutual exclusiveness between liberty and enforced equality.
We can only monitor the condition. On a longer and accurate encyclical view they cannot understand the most dangerous
place they are actually in.
As you can see they are stuck at level III since they are not Democrats.
“It just didn’t compute to us that the same people creating working-class propaganda are creating essentially propaganda for corporations,” Hayes said.
“We did this really with the goal of building kind of an effective, functional left media structure,” Burton explained.
https://fysociety.net/how-a-ragtag-grou ... s-of-2018/
If you missed the trend the progs have already infested netflix....
I guess the guys sworn to protect missed this as they ghost dance.
The move to fill the void we warned of clearly.
https://www.zerohedge.com/news/2019-01- ... tive-media
https://www.zerohedge.com/news/2019-01- ... oss-border
The abundance caused by the revolutions will lead to hard to fathom changes in international political relations. We surmise that much of the oil importers’ urge for political intervention and control will dissipate as access to oil becomes less urgent. For instance, the heavy diplomatic and military presence of the US in the Middle East is likely to be questioned when the country’s dependence on oil from the region is further reduced.
May 3, 2016 SA
No we did not forget either.
As for the space cadets nominal taxes and spending rhetoric it is out of date and place.
The only decline is the current cargo cult rational thought map and the current rate of transfer.
Since 2008, U.S. installations have grown seventeen-fold from 1.2 gigawatts (GW) to an estimated 30 GW today.
We already discussed molten salt storage from MIT and the trend will be decided by the market since we are from the government
and here to help. Even the last administration was forward enough to admit back it has a monopoly in violence.
aedens wrote: Tue Oct 15, 2013 9:44 pm
Circles are typical and some are just old excuses to skin you. As for the current blend of thoughts we will watch the paradox of thrift as noted bear it own facts since they crafted it. Also taxpayers do know right from wrong. Caeser is dead I owe him no dues. Paying idiots to be idiots means we are. Locally we can get by with the Mayor and Sheriff and the Govenor the nerd who balances a budget but much after that is truly text book how to be fish heads.
H wrote:
What should happen is the taxing authority should be entirely within the state and local governments; the Federal government cannot tax. Then the Federal government should be required to come to the Governors with a budget and the Governors can decide what to fund out of that request. The underlying theme would be that the Federal government works for the people of the states, not the other way around.
John wrote: But plenty of shouting and finger-pointing.
aedens wrote:
Todays news:
Weapons - none
Religion - none
Press - none
Leadership - none
Caeser - none
Yes indeed Generational Dynamics has a good sense of irony and good cheer to admire the statist’s wet dreams on the crucible of history.
Whatever the technical legal ratio decided of the case, the public at large widely understood the Somersett Case to mean that, on English soil at least, no man was a slave.
I beg to differ on the abuse of usury and debt in any realm. No one is going to save my ass.
Anyways after they looted our district here we are, yes we did the math and sidelined our projects.
For wherever violence is used, and injury done, though by hands appointed to administer Justice, it is still violence and injury, however colour'd with the Name, Pretences, or Forms of Law, the end whereof being to protect and redress the innocent, by an unbiassed application of it, to all who are under it; wherever that is not bona fide done, War is made upon the Sufferers, who having no appeal on Earth to right them, they are left to the only remedy in such Cases, an appeal to Heaven.
John Locke, The Second Treatise of Civil Government.
As we suggested early and often the man of perdition would be a script we both noted to agree on.
On another note "Greece is the first battle of what comes to be known as The Cold War. His speech to the US congress asking for money to fight communism worldwide, but particularly in Greece, becomes known as The Truman Doctrine. America joining the fray is vindication of a sorts for Winston Churchill. President Roosevelt believed Great Britain's policies in Greece were a mistake and that people had the right to work out their problems democratically without influence from the outside." I feel the same way in a very volatile region with limited resources. http://www.ahistoryofgreece.com/civilwar.htm
I think Obama sent a clear message to the military in correct context to internal realities of other people’s problems. I still remember the Kurds being annialated as others watched with no regard so over all I have mixed emotions as was done in Poland also near the end of WW2 also to the western seeking freedom fighters who fought the Nazi as the Red Army watched the political theater playing out. The fact of the matter also it means my Nephew will be out of that region. For our family two generations in the Military in the Middle East is enough. I do not hold any pretense about what will ensue to regional stability's and again I thank the forums for views that convey trends we observe and John's work to conveying a sense on current affairs we can talk about.
I think some may remember Hadrian as seen from Aelius Spartianus point of view. As we also know they will search and not find.
Ask GE and the previous cult how that worked out for real taxpayers.
Thread: Amos, Ankara, Shinar
https://www.zerohedge.com/news/2019-01- ... fter-comey
Zombies from the body farm.
Huber has been nothing more than a front man to provide cover for the illusion that Sessions would do his job.
Unfortunately, Sessions did a great job stonewalling and allowing the Progs two years to get back into power.
The only other dot that needs connected is Rosenstein and the wearing of a wire that McCabe suggested to trap Trump and force a 25th amendment crisis. I suspect that little crumb is being saved by Trump when Rosenstein is finally axed by the new AG. That demon is another true machiavellian cancer in the swamp. fxd
What happened next? Well, a collusion narrative was born and carefully crafted as the paper explains...
No it was already inplay.
Outer probe check to detente warfare since it is obvious to taxpayer the corruption.
Quid Pro Quo harassment.
Two other Clinton Foundation whistleblowers reached out numerous times to Huber’s office, starting in April, and offered to turn over 6,000 pages of evidence, only to get the silent treatment for several months before finally hearing back after Republican leaders supporting the expert witnesses made a stink about the snub on Fox News.
Private financial-crimes investigators Lawrence Doyle and John Moynihan say they got no response after sending evidence of alleged foundation tax fraud, misappropriation of funds and pay-for-play schemes to Salt Lake City by mail in April and again in May. After hearing nothing back, they followed up and were told the materials had been “lost." So they re-sent them by FedEx in October. But again, they heard nothing. Then, finally, they received a call on Nov. 30 from an assistant U.S. attorney there, who said he would “review" the material.
“It’s disappointing it took that long,” said Moynihan, a former Justice official.
Actual issue is the wrong people are getting payed. Federals are out of control feather nesting in K and J MIC monsters.
Unfortunately other monsters are real outside the borders also. Mr. Market has some really morbid habits since 1871.
And yes Wall Street was invaded from the Sea also.
4. Use a straw man. Find or create a seeming element of your opponent’s argument which you can easily knock down to make yourself look good and the opponent to look bad. Either make up an issue you may safely imply exists based on your interpretation of the opponent/opponent arguments/situation, or select the weakest aspect of the weakest charges. Amplify their significance and destroy them in a way which appears to debunk all the charges, real and fabricated alike, while actually avoiding discussion of the real issues.
5. Sidetrack opponents with name calling and ridicule. This is also known as the primary attack the messenger ploy, though other methods qualify as variants of that approach. Associate opponents with unpopular titles such as “kooks”, “right-wing”, “liberal”, “left-wing”, “terrorists”, “conspiracy buffs”, “radicals”, “militia”, “racists”, “religious fanatics”, “sexual deviates”, and so forth. This makes others shrink from support out of fear of gaining the same label, and you avoid dealing with issues.
6. Hit and Run. In any public forum, make a brief attack of your opponent or the opponent position and then scamper off before an answer can be fielded, or simply ignore any answer. This works extremely well in Internet and letters-to-the-editor environments where a steady stream of new identities can be called upon without having to explain criticism reasoning — simply make an accusation or other attack, never discussing issues, and never answering any subsequent response, for that would dignify the opponent’s viewpoint.
Todays tactical.
11. Establish and rely upon fall-back positions. Using a minor matter or element of the facts, take the “high road” and “confess” with candor that some innocent mistake, in hindsight, was made — but that opponents have seized on the opportunity to blow it all out of proportion and imply greater criminalities which, “just isn’t so.” Others can reinforce this on your behalf, later. Done properly, this can garner sympathy and respect for “coming clean” and “owning up” to your mistakes without addressing more serious issues.
The reason it will not go forward are top level GOP players involved since they are the cone of the actual ice cream.
Democrat Tulsi Gabbard announced on Friday that she would run for president in 2020.
https://www.yahoo.com/news/kamala-harri ... 24721.html
For the compromised dnc and sanity yes the Woman from Hawaii the other is clinical.
Because you insult the People who sent Him for over two years already you do not deserve respect.
The Serfs in Medieval Times paid 1/3 of their crops to the Lord of the manor.
The rest they got to keep.
The democrats have gone full blown socialist retard.
Only nine days in the filthy keep for unpaid coin taxes unless redeemed for coin when the Church pressed the issue
when Simonde conveyed the reformation period after the slaughters.
2020 is going to epic.
Federal Reserve Bank of St. Louis and U.S. Office of Management and Budget, Federal Receipts as Percent of Gross Domestic Product [FYFRGDA188S], retrieved from FRED, Federal Reserve Bank of St. Louis; https://fred.stlouisfed.org/series/FYFRGDA188S, January 12, 2019.
One Third of Wall is adequately completed with Renovation or New Construction and only South Texas ( 110° in Summer ) miles needs built, if understanding some Wall needs are low priority, ( wrap-up miles ) where foot travel is less Concealing and more Mountainous or Threatening, like Big Bend Texas area, ( 250 - 300 miles ) where foot travel would add weeks of travel time and supplies are extremely limited. So about the end of February having the Government shutdown because of a Already Built Wall will be then a Muted argument !
Ignore the stupid and finish the choke points please and thanks.
Please flush our the bilge tank called Washington.
Keep it afloat since its your damn job.
Sat Dec 02, 2017 6:32 pm
Baudrillard was absolutely correct. “Information devours its own content. It devours communication and the social…. Rather than creating communication, it exhausts itself in the act of staging communication. Rather than producing meaning, it exhausts itself in the staging of meaning.” In the age of advanced ‘communications’ meaning evacuates to be replaced by a simulation of reality directed by whomever is pulling the strings. And since everyone’s socialized identity is entirely contingent upon their ability to stay abreast of the latest vehicles of communication, the twitterings, the ’social networks’ etc, the absorption of meaning by content is in direct proportion to one’s media hipness – and that hipness in turn in directly inverse ratio to actual lived reality – one is aware, exclusively, of their awareness, which is content provider and information fused together into the perfect simulation of meaning – aka meaninglessness. “The real abolished.”
peak propaganda is upon us
https://www.zerohedge.com/sites/default ... k=zPlAALPP
now we sort the alleged rational actors
Way back in the forums we noted this also as It is also known that the Barzani clique which controls that statelet is a dependent of Ankara, which acts as a conduit for the transfer of the stolen Iraqi gas oil which Erbil is selling to Tel Aviv via the Turkish port of Ceyhan.
I have great respect for the Russian people and agree that they can survive just about any hardship. I'm unaware of any evidence that the small amount of actual fracking that has gone on in the US has turned the nation into a "poisonous swamp". That sounds like leftist propaganda. I appreciate your wishes for good luck, same to you and yours. As we are also reminded ironic at best is the condition of many people and tongues.
Your Authors speak timeless truth that the Kingdom of God is within you. I gave my Copy to a Hindi when he legally immigrated here.
The Kingdom of God Is Within You is a non-fiction book written by Leo Tolstoy. A philosophical treatise, the book was first published in Germany in 1894 after being banned in his home country of Russia.
Last year Turkey interdicted with a large armored force into Northern Syria on a path to take them right on top of US forces, until the Russians started to drop gravity bombs on an unimportant empty region directly in the path of advancing Turkish forces.
Being white is a responsibility. Sorry Deep State.
Now we wish a few answers for the three Journalist in the CAR region purported to being your stained baggage.
Wagner fighters, many of them drawn from central Russia’s dilapidated Ural region, have confirmed the group’s monetary allure.
A unit of the group, filmed by the recently deceased journalists, was operating in rebel-held territory—contrary to Moscow’s assertions that Russian forces were present only to assist CAR authorities.
http://africanchronicler.com/three-russ ... -republic/
Wagner mercenaries launched a surprise assault on U.S.-backed Kurdish forces in northeastern Syria, eventually suffering hundreds of casualties in a four-hour firefight that saw heavy American airpower brought to bear on the group. The result: a public-relations catastrophe for the Kremlin, which struggled to explain the nature of these mercenaries who had just assaulted U.S. positions, while covering up dozens of deaths. Judging from the haphazard and repeatedly revised Kremlin explanations of the event, it seems unlikely that Russian officials were apprised of the scale of the assault or its targeting of Americans. But Wagner’s position ultimately depends on the mercurial personal relationships among Prigozhin, Putin, and other top Kremlin officials.
https://www.youtube.com/watch?v=yQZ6Bkn-EQQ They do not realize as the message is silent for you.
thread: calamity politics
Users browsing this forum: No registered users and 19 guests
